Dynamo node "Element.GetParameterValueByName"
jessica_vazquezKLYLC
I'm going through some online tutorials to change information in curtain panels all at once instead of selecting them manually. I came across the node "Element.GetParameterValueByName" but I don't seem to find it under that name, since I'm new to Dynamo I was wondering if now it's under another name.
I'm using Revit 2023 with Dynamo version 2.13.1.5510
ralphdenhaan
I think it is still under the same name. The search function requires you to fill in the name exactly.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Thank you so much, I spent a lot of time yesterday looking for it and couldn't find it. But I get now, I can't believe it was that simple 😂
