Dynamo List MinimumItem
endison8
endison8
Hi everyone,
I was trying to get the lowest room surface by comparing their Z value of center point.
I tried to use "List.MinimumItemByKey" and "List.SortByKey", but both of them didn't succeed.
Finally, I used "filterbyboolmask" to do the job.
However, I am very confused why the other two methods failed("List.MinimumItemByKey" and "List.SortByKey")?
Can anyone tell me? Thank you very much.
RDAOU
@endison8
They are not working for 2 main reasons:
  1. You are using them outside their intended use
  2. They expect an input which is 1) a function and 2) a variable BUT you are feeding them with a double
Apart from the above you are over complicating a simple graph. If you want to get rooms sorted based on lowest/highest, you can simply use the Top Offset Parameter of the room.
endison8
@RDAOU
Hi, thank you for the quick reply.
I'm not sure I get it right but I wasn't getting the lowest/highest room though.
I was trying to get the "bottom Surface" of the room, that's why I want to sort or get the minimum z point value of all the room surface centers.
RDAOU
@endison8
Then use the following...you can extract/filter faces (Top face or bottom) >> perimeter curves >> start point >> Polygon.bypoints >> Polygon.Center >> Flatten >> Point.Z
  • Then use the node List.SortbyKey ... to sort the Room List from lowest to highest
Works better in case the rooms are under a sloped or curved roof
endison8
This is GREAT!! Thank you very much!!
