Dynamo - get revit parameter
spm8C88E
spm8C88E
I'm still learning Dynamo, but I think it should be possible to do what I'm trying to do. I'd like to take the information in a built in revit paramter, like Workset in this case, and populate a second parameter with this information. For some reason it looks like I can get other built in parameters, like "Name" or "Comments", but when I try to access "Workset" Dynamo returns zeros instead of the Workset name. Is there another way to access this parameter?
M_Meshal
You can use "Element Workset" node from "GeniusLoci" package, it will help you to get the name and the workset it self.
spm8C88E
Thanks for the suggestion! Is there a trick to this node? for me it still only returns null values
s.iwasakiSYTFM
It appears to be working in my Revit and Dynamo.
It may be a version issue.
You might want to check with repository, etc. or ask on the Dynamo forum.
Here is the version I am using
・Revit2023.1
・DYNAMO v.2.16.2
・Genius Loci 2023.7.13
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Satoshi Iwasaki
ONESTRUCTION Inc.
spm8C88E
@s.iwasakiSYTFM  thanks for your reply.
I'm running
Revit 2024.2
Dynamo Revit 2.19.4
Genius Loci 2024.5.29
IronPython2.7 3.2.0
I was getting some warnings for these packages so I uninstalled and reinstalled them but it doesn't appear to have helped. Posted on the Dynamo forum. thanks!
azad.Nanva
you can try this:
this is with your way:
M_Meshal
Are you sure your model contains worksets? (worksharing enabled)
