In Revit 2025, while I am working on a project I usually have three tiled views horizontally (left switching between floor plans, middle switching between horizontal sections and right switching between vertical sections).
I need to model a new family to place in my model. Revit opens all views (left, front, reference level and 3D view) in same tiled view. Similarly to project workflow, I want reference level in left tile while having elevations and 3d view in other two tiles. Is this even possible? You can click on desired view in Family model Project Browser and click Open, but it opens it in the same tiled view. If I select middle or right tile, Project Browser automatically switched to Project model Project Browser...
Any suggestions beside closing the project while modeling the family?
Thank you and best regards.
You can open a second instance of Revit. Use one instance for your project and the other for family editing. This allows you to keep your project open in one window while working on the family in another. This way, you can manage views separately in each instance. Revit doesn't natively support maintaining the same tile arrangement for project and family views simultaneously within a single window
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
