Dynamo counting
Dynamo counting
Dynamo counting
Could someone create a dynamo which adding ordinal number in the loop of smoke detectors?  We will get in label number of loop/ ordinal number of smoke detectors like a S1/1, S1/2, S1/3 etc etc.
Could you help me to create this kind of dynamo?Please
L.Maas
What do you mean with "in the loop of smoke detectors"?
Do you want to add a sequential number to all the smoke detectors?
What dynamo script did you create sofar? Can you upload that or post a screenshot? Then we can try to build from there.
Louis
Please mention Revit version, especially when uploading Revit files.
Exacly, sequential number!
When I create a circuit with smoke detectors in a fire system, I would like the dynamo to number more smoke detectors.
I've never done anything in a dynamo, and I need such a dynamo to work. I would ask for help in creating such a script.
BR
L.Maas
Sorry, but I am not here to do your work.
First give it a try yourself. Get yourself with familiar Dynamo. Then when you are running in specific issues I/we will try to assist you.
On the dynamo website you will find plenty of tutorials to get you started.
Louis
Ok, I understand. I made that dynomo in attachment.
Unfortunetly, it didn't wotk in my fire systems.
Could you change that dynamo that I could use in fire system and I could put the value in that sequence: number of module/ordinal number in fire smoke detector.
I model on this tutorial:
https://www.youtube.com/watch?v=9peUNxoLW3E&t=93s
