Revit 2018.3 is crashing too many times on only of the systems.
Hardware (RAM, Graphics) are same as per other computers but still only few selected are getting errors.
Its too frequent and its closing down very half an hour and its very difficult to work.
I already disabled add-ins but no luck.
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... try to uninstall REVIT
..... then clean your PC
... use Ccleaner or Disk Cleanup
.... reboot and install it again
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
hello, did update to the latest version? try to install latest updates and see if helps. thanks
