DWG looks different in Revit than in autocad
I'm importing a dwg into revit, and it looks like som of the lines have moved on the wheels.
When opening the dwg in AutoCad, nothing is wrong with it.
How do I delete those lines.
what's known: lines are on same layer as the rest, and the lines are correctly placed in Autocad.
(See picture for reference)
tbh I didn't know whether to put it here or autocad forum, so show mercy.
Apperntly picture is not working so here it is again
Those blue lines are Sheet Grid Lines.
...If you are referring to DWG Linework, and that Linework in on a Layer, you can turn off those Layers in Revit.
Sorry for not explaining further. I'm talking about the small cirkels that look like they are popping out of the wheel.
I ended up trying to delete different lines on the wheel and at some point found the right ones.
TripleM-Dev.net
Post the dwg file, maybe it's a element in the dwg that's just not visible or has invisible edges like a 3Dface.
When linked into revit it's border will become visible.
- Michel
s.borello
Try linking the CAD file with only visible layers.
syman2000
I assume you talking about this? AutoCAD have a command called SPLFRAME and set it 1. It will unhide all hidden 3d invisible edge. Use that and then delete those object.
