DWG files to Revit
3 REPLIES 3
2283 Views, 3 Replies
DWG files to Revit
What is the best practice to migrate project DWG ACAD Files to Revit files, so that the project is documented in Revit instead of AutoCAD?
Many thanks.
3 REPLIES 3
the best practice to migrate project DWG ACAD Files to Revit files is don't do it.. the VERY best practice- (and this is not something everyone agrees is necessary- but i believe it's best)- is to import the DWGs into a SEPARATE session of revit and use it for reference to build whatever it is in your revit project..
rosskirby
I'm assuming that you have some CAD plans and that you'd like to "restart" the project in Revit, is that right?  If so, the best practice is to link the CAD files (not attach) into the corresponding Revit view and use it as a guide for "tracing" your Revit walls/floors/etc. on top of.  When you're done, just remove the link and you're CAD-free.
If you have some sections/details in CAD already, there's no way to directly convert those into "live" details.  Although if they're standard details and unlikely to change, there's really no reason you can't link or attach them to drafting views that are referenced from your model.  However, I would caution that this is a last-minute, short-term solution, while the better solution is to re-draw the details natively in Revit.
Hope that helps.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
in reply to: rosskirby
hey wow- here's my best friend that i met at the new AUGI forum that's not anymore: >rosskirby<- so glad to see you again..
