Duplicate Parameters at schedule field
kvusal
kvusal
Dear Experts,
When I try to add parameter from available field I realized that there are duplicate parameters.
i.e.: 3 pcs of length parameter:
What is reason of that?
Don't feel bad. We have all been there. We have created shared parameters with the same as existing system parameters or we recreated shared parameters in another Shared Parameter TXT file with identically parameters as another.
Anyways: read this blog. It was the end all and be all for me.   Yes, I'm dead serious.
https://revitoped.blogspot.com/2012/09/shared-parameters-aka-dictionary.html
Best analogy ever. "The Dictionary analogy".  Thank you, @SteveKStafford
Those are shared parameters with the same name but from different sources (aka different GUIDs) coming in your project from different families.
izchelrendon
Hi! How you solve this?
Edit the families and replace the existing parameters with shared parameters from the same source shared parameters text file.  There maybe some add-in to assist with that task, do a search.
izchelrendon
Thanks!!
