duplicate instance of CAD links (visibility graphics)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all!
We have the following situation:
In the Visibility/Graphics ALL linked DWGs are duplicated, without exception.
Imported objects styles happens the same.
The duplication happened once to all the links.
We noticed that:
When turning the visibility OFF of one of the linking instances (the second represented in the picture above), the dwg was still visible, whereas when doing this to the other, the dwg visibility behaved as expected (not shown).
We know that:
We only have one instance of this linked dwg. We ran one simple Dynamo script and used BIMlink to confirm that.
No one created similar instances of the links. We would have seen the “name of the file + (2).dwg” inside the imported categories of the Visibility/Graphics.
BUT:
When the dwg was completely removed from file and loaded again, the problem disappears. However, this is a project that heavily relies on CAD underlays (yes it is a bad practice) therefore we want to avoid remove/add solution since our visibility settings will disappear as soon as we remove the link from the file.
Has anyone had the same problem with DWGs and was able to solve it without the remove/add solution?
Thanks in advance
