- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm a proficient ArchiCAD user who decided to start learning Revit 2021 by dissecting/taking apart some sample projects. A very good sample project that I'm using is the Austrian "Golden_Nugget" that's downloadable from ADSK.
I've been stuck the past few days (tried searching and Google) about some project parameters which use a dropdown menu. The ones I'm referring to are located within the view properties under "constraints" and are called "Projektbrowser Ebene 1/2/3" and they have dropdown menus which forces the user to make a choice.
Where are the dropdown menu choices located? I wasn't able to see them under Manage -> Project Parameters. Also, I can't seem to change the discipline and parameter type for existing ones only newly created parameters. Is this intentional with no way around once you create a parameter?
