Drop-Down Parameter for a text type parameter in a Family
camirozario
camirozario
Hey guys, I wonder if Revit allows me to set a type parameter for a family that is a drop-down list with some text tags ( I just want the user to classify the family with some texts without having to type it in the project, so the person can rather just choose the text from a drop down list with a limited amount of options)
Thank you
Yes.  It is the same answer to your question about selecting different symbol.  Use a Family Type <Generic Annotation> to choose different text from nested family types.  See example family attached.
camirozario
Thanks for the reply! I thought about doing that but because my family has other generic anotations in it, the drop down menu selects all generic annotations in my model. Also even if I delete the ones I don´t want but lod my family into a REVIT model it ends up also adding to the list all generic annotations in my main model 😕 Anyway I can solve this?
Also when I mention " text" i just want a typed property in my model (not an annotation itself) so this might open a wider window for solutions.
* ALso I am having issues when adding this set to a filter as all the Gen. Annotations in my family appear as an option. I would like just to create a text field that I define as sort of a indentity data of my object (?)
Thanks again!
lim.wendy
Hi Camilla,
Thank you for submitting your question in our discussion forums. Have you had a chance to look over the suggestions provided by Toan? Please let me know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
camirozario
Thanks! I still couln´t figure out how to do it but will keep you posted if I manage to figure it out! Thanks so much
camirozario
I tried working with LookUp tables but it didn´t work as I expected, however I was able to create something that was a bit better than what I was doing previously! ( Basically, I defined numbers to categorise my families and that would set a text to my family according to the number that I set in my lookup table - therefore my user does´t need to type the whole text). I have also a question about those lookup tables. Is it possible to use it to set family types (like nested families in my family?)
