Draw order of Structural columns
harsh.patel
harsh.patel
Hi all,
I have question regarding the draw order of structural column. How can I bring it to front? I want to apply the solution to entire project ( to all columns) not just to single element. see the attached.
_Vijay
Did try join geometry and switch geometry....if its not help. please sample file we will try to help you further.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
martijn_pater
Is it a linked stuctural model? One way would be to set the viewrange slightly lower then it is in the linked view.
harsh.patel
Hi Vijay,
I tried to join elements. Still not working or may be I am not doing it correctly. Due to data protection policy I won't be able to share entire model. However, I am attaching the sample file here.
bin
Try this:
1. Edit your Structural Column.
2. Go to plan view.
3. Add symbolic lines, choose subcategory Structural Column [Cut]. Place 4 lines and lock them onto reference planes.
4. Load back into the project.
Please let me know if you find a better solution.
harsh.patel
It did work. Thanks a lot.
I do not have a better solution currently. If I find it, will post it.
Also I am new to Revit so still exploring it.
