Draw colunms
Draw colunms
Draw colunms
When I try to load rectangular column in revit 2015 I recieved the msg that it is already in the family. I couldn't load it and place it...
Pls give me a solution
kadmonkee
are you trying to load a Structural Column or an Architectural Column?
look in you project Browser / Families /Columns or /Structural Columns
if they are already loaded then you should find them in either location
from here you can drag th etype you want into your view
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
I just started to use revit. May I know what are the differences between
structural column and architectural column. And thanks a lot for the reply
sir.
Kimtaurus
Architectural column: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Structural column: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
