Downspout
Downspout
yes_and_no
Message 1 of 10
Downspout
yes_and_no
Guys, I always have trouble with downspouts.
A. I created simple, no turns, generic wall base family with "type" ref height. I wanted it to be under Roof property, says "Downspout", where I can change it colors by Project Parameter. But Roof category is not even available.
B. When insert to Rv, it snaps to the walls alright, but it won't lock to the ref level automatically (ground level), making more time to complete the task.
Q: how to solve A and B ?
Happy holidays.
Accepted solutions (3)
Replies (9)
Message 2 of 10
RDAOU
@yes_and_no
  1. Roof category is  only available in the model...If you want to schedule as a roof...You can do the following:
    • Start an Inplace model and select Roof Category
    • Place the component in and finish inplace
  2. If you want it to lock to Levels, you can model it using a Column Family or generic 2 Levels based family which locks to Levels. One cannot have it all. Nonetheless, a Wall/Face or Workplane based should be more than  fine with just the height parameter to be change!!!
Message 3 of 10
Why roofs category?  I would create it as a line based generic family, or a wall based generic family, or a 2-level based generic family.  I would even consider creating it directly in the project as Plumbing pipes.
Message 4 of 10
Sounds like you are having a great deal of difficulty with the one you have.  What about just downloading and using a another one? For instance, this fairly typical downspout (from Revit City) is fully parametric:
Message 5 of 10
yes_and_no
This is exactly the one we are using right now. Won't snap both to wall and base level, no way to know instantly where it is on roof plan.
No trouble, just want to work faster with smarter family.
Message 6 of 10
Set the Roof Plan to Wireframe View.  That make it easier?
Message 7 of 10
Actually, I'm not that impressed by that family. I'd use another one or rebuild that one.  If I were to rebuild it, I'd place all the Ref. Planes outside of sketch mode and add Ref. Lines for Angles. I'd drive all the RPs and RLs with Labeled Dimensions and align/lock all the extrusion sketch linework to those RPs and RLs.  I'd also make all the Parameters Instance-kind, so that I could tweak placed instances of it in the Project using shape handles.
FWIW.
Message 8 of 10
syman2000
You can use mechanical pipe to draw your downspout. However Revit treat the join and turn as each pipe segment. So I would just use default family created by manufacturer to keep it simple. See attached.
Message 9 of 10
What was the reason for this?  Not knowing where it is on the Roof Plan?
Message 10 of 10
pdent1
I'm bumping this old thread because we always have a need to offset (slope) downspouts parallel to the building face. All the downspout families I've seen only have offsets perpendicular to the building face. In the past we have used model-in-place but I'd like to get away from that. We have a perfectly good scupper/downspout/splash block family, and I tried removing the scupper and splash block, keeping everything else the same, but it can't be rotated from vertical. I'm not much of a family editor guy--what am I doing wrong?
