Double window is not displaying properly
S.J.terSchure
Message 1 of 9
S.J.terSchure
Hi all,
I'm working on a stacked window family in Revit 2022. When I finished my family and loaded it into the project, the window didn't cut properly (it shows the top window in the cut view). According to other forum topics, I had to set my view range in the family editor, but this didn't solve the problem and still the top window is being cut in the plan view inside the project. Also changing the Frame/Mullion category into not visible in plan wouldn't solve the problem.
Am I missing something?
ElevationElevationPlan view in the projectPlan view in the projectView from the family editorView from the family editorWindow settingsWindow settings
Replies (8)
Message 2 of 9
ennujozlagam
you need to edit your family and add symbolic lines to reference level to show once it loaded? thanks
Message 3 of 9
S.J.terSchure
Thank you for your answer. But this solution is just adding lines that would be displayed in my view. Isn't there an option where the geometry of the sweeps is cutting correct? And not showing what is above my cut plane?
Message 4 of 9
ennujozlagam
you can try plan region, view range and set the setting value ? thanks
Message 5 of 9
RDAOU
@S.J.terSchure
Upload the family you created
Message 6 of 9
Message 7 of 9
Toggle your "Preview Visibility" ON in the Family and post a screenshot of what you see in the Family Plan View.
Message 8 of 9
Check the family and see if the window sashes are set to be visible in Plan/RCP and for the detail levels you want them to show.
Message 9 of 9
S.J.terSchure
This tip definitely helped a lot. Thank you!
