double sloped floor
double sloped floor
kmatzumura
double sloped floor
kmatzumura
Is there a way to build a double sloped floor os something similar on Revit?
I'm working on a project that has an open parking lot. The site has a slope in an "east-west" direction and also because of the levels of the project the parking lot needs to have another slope in the "north-south" direction, so the parking lot floor should have a double sloped floor. I'm using a building pad to cut some of the site (the topography is pretty irregular) and I'm also using floors for the parking lot.
I hope you understand what I'm trying to explain.
Greetings,
constantin.stroescu
Is this what you want?
Constantin Stroescu
kmatzumura
Thank you for your response.
Yes, I'm trying to do something like that to a floor, is it possible?
constantin.stroescu
There are two methods:
  1. Using Sub Elements :Select the Floor > Modify Sub Elements > (work in a 3d View) > select the small green rectangles placed on the corners and change the Z value . From Properties (with Floor selected) > Edit Type >Type Properties > Structure - Edit > Edit Assembly -Layers -you can use Variable parameter (to be applied to the structure or to other layers)
  2. another method is to use the Slope Arrow : select the Floor > Edit Boundary >Slope Arrow
The first method allows multiple slopes and it is a better solution
The second method allows only one slope....
Here you can find  a screencast showing The Sub Elements and the Slope Arrow methods:
https://screencast.autodesk.com/main/details/bf64ad62-7354-4e85-83ed-c0f51e65f76
Constantin Stroescu
kmatzumura
Thank you very much! This has helped me a lot 😄
