Double panel on curtain wall
Szigeti.Eduard
Message 1 of 10
Szigeti.Eduard
I created this plasterboard wall as a curtain wall system and I added a layer of plasterboard as panels.
I want to add a second layer of plasterboard on the top of the first one, but I want to start with a piece of 600 mm and the rest of the panels be 1200 mm.
Can anyone help me to do this?
Replies (9)
Message 2 of 10
You could place another Curtain Wall. How about that?
Message 3 of 10
syman2000
You can use offset value. So it start 600mm first and then 1200mm for the rest.
Message 4 of 10
syman2000
Also I would use wall if you want to have double layer Gypsum. See attached
Message 5 of 10
linkboy
unlock the CW grids to adjust panel.
Message 6 of 10
...how 'bout just scrapping the whole double-whammy curtain wall panel and replacing all the curtain wall panels with a compound-layered basic wall type?  That work?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Message 7 of 10
Szigeti.Eduard
Unfortunately it won't work as I model for construction, not for rendering and I need every small detail of the wall type so I can accurately animate the whole construction process.
Message 8 of 10
Szigeti.Eduard
That would solve one problem but will create another.
I need to get rid of grids and lock the both systems together, also I need to put insulation and pattresses and for that I would have to create a different curtain wall for each.
Message 9 of 10
Szigeti.Eduard
It would work if I could select the second layer separately, but the grids are common for both layers and moving one grid will move both layers and I need staggered panels
Message 10 of 10
Szigeti.Eduard
Yes, they are two layers but they are not staggered.
It would be great if I could select the panels and replace the first one with a 600 mm panel and continue with 1200 after, but Revit will not let me select the panels.
