- Mute
- Permalink
- Report
I have an aluminum door family in my project, the type that can be used in a curtain wall. There are 8 of these doors visible, which is how many I expect to have, and how many I see when I "select all in view" from a 3D view (uncropped, no section box, no scope boxes, phase filter set to none). However, choosing "select all in project" there are 31 of these doors. The other 23 are not visible in any view and do not show in the schedule. I thought they might exist in unused groups, but there are no groups in the project with walls or doors of any kind. Other things I've tried:
-Used CTC Tools "Quick Select" from the "select all in project" option - Revit "can't find a good view" for any of the invisible doors
-Checked worksets, phasing, and design options, which I can see in the properties menu when all 31 are selected - all 31 of them are the same, Workset1, New Construction, and Main Model respectively
-Accepted the primary Design Option, deleting all others, and they're all still there
-Changed the visible doors to a new family (and inversely selected all in the project, changed all of them, then changed the visible ones back) in attempts to purge the non-visible doors by type, but in both cases the type assigned to these doors does not appear in the purge list
Ultimately, I was able to find a tool in PyRevit (wipe selected family) that did the trick, but I'm baffled as to where all these phantom doors exist in the model in the first place. I'd like to figure that out. Has anyone else encountered something like this?
