Doors and windows do not cut the wall
hi
I'm using skirting board Add-in to make a wall that is A plaster layer on wall
but windows and doors sometimes cannot cut the wall wit new layers.
Join Walls not working to extend the Opening Cut?
If not, swap out the Opening Cut in the Door/Window Families for a Void Cut to cut the Host. Extend the Void Cut past the Wall faces. Then check "Cuts with Void when Loaded", load into Project and use Cut Geometry to cut the opening through the other Walls.
I want to check out this Add-in you are using. Can you provide a Link to it?
syman2000
Have you try Join geometry with the plaster with the existing wall?
You just need to join geometry the skirtboard wall with the main wall.
it woks when join main wall to plaster wall
but it takes time 🙂
thanks for helping me , and if you have video that shows how to edit OPEN CUT in family , it will be great
thanks again
addin link
Room Finishing | Revit | Autodesk App Store
Thanks for sharing link.
FWIW: Revit can make wainscots too - ones that are cut by door/window openings - using the Wall Sweep tool or by building the wainscot/sweep into the Wall Type.
Wall Sweep:
Wall Type with built-it Wall Sweep:
or...Wainscot Material Painted onto a Split Face:
