DOOR SCHEDULE
DOOR SCHEDULE
s3687147
Message 1 of 8
DOOR SCHEDULE
s3687147
I create a door schedule but i would like to add door tags to the schedule. see attached images.
Also door numbering is starting from 25 why? is there a way to controlPLAN.JPGSCHEDULE.JPG it ?
Thanks.
Replies (7)
Message 2 of 8
bin
The number in your Door Tag is Mark Parameter.
Revit will automatically assign the Mark after the last one you have.
Message 3 of 8
s3687147
thanks for your response but where can i find  door number 1,2,3 etc...
Message 4 of 8
bin
Edit the Mark of the first door you placed, change it to something like D01, then the following doors will be numbered after that. Most of the time you still need to renunber then anyway 🙂
Message 5 of 8
s3687147
Awesome problem 1 solved. thanks.
my second question is how do i create a door schedule showing door tag number EXAMPLE : D01 on the first column and size on the second?
Message 6 of 8
bin
Just add Mark into your schedule. I’m on my phone so can’t screen shot for you.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
go to this one
Message 7 of 8
s3687147
Thanks so much!
you are a legend.
Cheers,
Michael
Message 8 of 8
@s3687147 wrote:
Thanks so much!
you are a legend.
Cheers,
Michael
Legends usually get Statues of them erected -- or Solution Credits.  😉
Just saying...
