Door quantity parameters
4 REPLIES 4
791 Views, 4 Replies
I make this kinds of door schedules.
Is there way to make text box or door tag or something else that shows total door quantities?
Which can be automatically updated..
4 REPLIES 4
You could do that through a schedule. I can see it done through the use of a Concatenate Parameter. However, it sounds like you want to tag the door with this information (e.g. "2 of 20 Doors", "3 of 20 Doors", etc.).  Is this an accurate reading?
in reply to: barthbradley
Yes, it will be best if I could add quantity of door on the door tags.
So that I can show a total for each door.
Door Schedule can only show by table, and that is impossible to show each quantities.
Thanks a lot.
Create a door schedule, filter and format it to display the Total only. Place that on the same sheet where you place the door legend.
...as a Door Tag? Interesting documentation method. That's new to me. Frankly, there's no way to do this in Revit without jumping through some hoops. But, you can do through a Door Schedule.
