Door placement in wall
mairh_tsek
Message 1 of 15
mairh_tsek
Hello all,
I want to place my door in the insulation as the image below (2nd case).
In order to do that I used two separate walls (one for the insulation and one for the concrete) and I also create an opening in the concrete wall. I am thinking that if I will do this approach in all the doors and windows that I have in my project it would be a mess with all of  these openings.
Which is the correct way to place the door like this in a wall structure? Do you use two separate walls or one wall ?
Thank you for your ideas!
Replies (14)
Message 2 of 15
ennujozlagam
hello, you need to consider your door jamb in real construction installation. thanks
Message 3 of 15
mairh_tsek
@ennujozlagam ,
 I don't have door jamb in this case.
Message 4 of 15
ennujozlagam
then, i still prefer the one wall with door you don't need to create door opening to another wall. thanks
Message 5 of 15
mairh_tsek
So is there any way having one wall to place the door like the 2nd way?
Thank you!
Message 6 of 15
ennujozlagam
No, if you have two walls, it's time consuming you need to create another void/opening for the door what happen if you relocate the door you need to delete the opening you created and make a new one? One wall with the door is acceptable in the real world
Message 7 of 15
ennujozlagam
hello, if you like something like this, please see attached just join geometry the two different wall type . thanks
Message 8 of 15
If I had many doors like this and also wanted good collaboration with the structural team, I would use 2 walls, but I would lose the opening cut in the door family.
Instead I would model a void extrusion in the door family (in the horizontal plane) and join the 2 walls together. It should cut both walls as expected.
Something like this:
I am getting this now without another opening in the concrete wall:
Message 9 of 15
mairh_tsek
@Anonymous ,
About your second approach with the void opening:
1. Do you have created two walls in the door family also?
2. Do you have placed the door in one wall, in the project ?
Thank you!
Message 10 of 15
There is only one wall in the door family (I don't think you can add 2 walls in the family editor).
The door is placed in the "insulation" wall and it also cuts the concrete one. The condition for that is that the concrete wall must be joined with the insulation wall in the Revit project.
Message 11 of 15
ennujozlagam
Hello, it looks like an interesting approach, don't mind to show to us, how are you going to do that. Thanks
Message 12 of 15
I made a quick screencast that shows how it works.
Basically you model the void extrusion in the door family and cut the wall in the family with it.
Then, in the Revit project you use the Join Geometry tool to join the two walls together.
After that, when you insert the door, the second wall will be also cut.
Message 13 of 15
mairh_tsek
@Anonymous ,
When I create the void opening in the family, the door profiles also are cutted.
See images below.
I am sure that I am missing something.
Thank you!
Message 14 of 15
In the door family, the void extrusion must cut your entire wall.
The smaller part of the extrusion is for the concrete wall and should be aligned with the door profiles on the inside.
Message 15 of 15
I managed to find Revit 2018 and did another screencast.
You can also find the family for 2018, but you would still need to align the extrusion correctly.
