Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Door opening cutting into wall behind
Message 1 of 8
Running into an issue with doors in the angled wall. For some reason, if I go to a door wider than 4' in this wall it cuts into the wall behind.
Replies (7)
Message 2 of 8
syman2000
Share the family. I want to check and see if void is used in the family. It may impact your object host and cut into multiple walls.
Message 3 of 8
Here is the family I am using.
Message 4 of 8
I have found that if I unjoin the corner the problem goes away. So I assume it is not caused by the family.
Message 5 of 8
Did you join the corner by Wall Join or Join Geometry?
Message 6 of 8
By wall join
Message 7 of 8
This is the corner I had to remove the join on.  @ToanDN
Message 8 of 8
Can you share the project or a portion of it?
