Door not showing in legend component
11 REPLIES 11
Message 1 of 12
teresa.afonso
514 Views, 11 Replies
I have a door family with nested families. In 3d it looks fine, also in elevations and sections. But it does not show in the legend component. I can see the dimensions controls but not the object. All the visibilty checks are on. Any ideas?
11 REPLIES 11
Message 2 of 12
in reply to: teresa.afonso
Set the legend view to Fine?
Message 3 of 12
teresa.afonso
in reply to: ToanDN
Already tried. Nothing
Message 4 of 12
Hi! The family has symbolic lines?
Gustavo Ubriaco Contreras
Message 5 of 12
Hi. No. Only model elements
Message 6 of 12
Check nested category inside the family and make sure the category is not turned off in the legend view.
Message 7 of 12
what happens if change the visual style?
also is the revit updated? if it's possible to get the family to check it in my revit
Message 8 of 12
FAIR59
shared nested families will not be displayed in legend views.
Message 9 of 12
in reply to: FAIR59
Are you sure about that?  Shared nested components show up just fine in a legend view here.
Message 10 of 12
FAIR59
in reply to: ToanDN
I stand corrected,  actually the 2nd level nesting isn't displayed
Message 11 of 12
teresa.afonso
in reply to: FAIR59
actually nested families do show up. I have used it several times.
Message 12 of 12
teresa.afonso
in reply to: FAIR59
That could make sense. But I remembered that I used families whith several levels of nested before, and I did not have any problem. For example, the following is a legend component of a family with several nested. It shows up.
