DOOR JAMB
DOOR JAMB
DOOR JAMB
I have tried to make the doors fir in a thin wall which is only 70 mm thick so I edited the wall thickness in the family editor. However the problem here is that there is a gap between the door jamb and the wall as seen in the image below. I have also attached the file for perusal.
Corsten.Au
Hi..
The door family needs to be corrected.
I have attached one Door family, you can use the same or
follow the constraints used in that.
Cheers!
Corsten
Building Designer
My suggestion is that you download and dissect a door family from one of the many manufacturers that offer Revit content (Marvin, Pella, etc.).
Any OOTB door family should work fine for various wall thicknesses.
