Door hosted by Generic Model family
emmanuelbee
Message 1 of 8
emmanuelbee
Is possible in Revit to create a generic model family that will be able to host a door?
Replies (7)
Message 2 of 8
Yes. Create a face based generic family and change the category to doors, then you can host it by a face of another generic family, or a face of anything else.
Message 3 of 8
emmanuelbee
will it show the cut of the door it like it normally does for walls?
Message 4 of 8
Yes. If you build a void and cut the solid in the face based door family. When you place the door on a generic model it will cut.
Message 5 of 8
brett_anderson
I want to place a Door face based generic face-based model into a generic model. This is so I can model clearances for the generic model (the generic model will represent an Air handler). The reason I want to use a Door face based generic model is so I can "walk" through it within Enscape.
The issues I am facing.
1. When I insert the DFBGM into the GM it won't show until I place a void in the DFBGM. I can't even give the DFBGM a material with a void on it.
2. I can't resize the DFBGM model in the generic model.
3. The DFBGM won't show in Enscape.
Message 6 of 8
You only need a void in the DFBGM if you need to cut the GM with the DFBGM.  And you should be able to assign a material to the DFBGM even with a void.  Share the family here.
Associate parameters of the nested DFBGM to parameters of the host GM.
Make the DFBGM Shared.
Message 7 of 8
brett_anderson
I've got the Clearance dropped into a Mechanical Equipment family just fine, and I've got sizing the clearance based on the WLH +1'. This is perfect. However the clearance family does not show on the plans. I want it show on the plans has red hidden lines and any time I try to put model lines in, some weirdness happens. So I'm not sure what's going on.
I have been able to get the DFBGM to show in Enscape AND it can be passed through. I've got a glass material set, but it still looks like it's a solid so again I'm not sure what's going on there.
Message 8 of 8
brett_anderson
So because it's a door family, the door category within Visual Graphics has to be turned on. I was also able to get rid of the void and create a clearance material that is completely translucent.
I got it working!!!
