Door family is not reflecting the assigned material
aman.kumarRVKHA
Message 1 of 11
aman.kumarRVKHA
The extrusion in below attached door family doesn't reflect the material. It should be simple but I don't understand why it is not acquiring the material I am providing.
Replies (10)
Message 2 of 11
Assign the material to Door Finish subcategory under Object Styles in project.
Message 3 of 11
You just missed one association downstream.
See attached.
Message 4 of 11
aman.kumarRVKHA
Thanks but I believe I did that as well but somehow the family I uploaded didn't capture that. Can you test with below attached one again !!
Message 5 of 11
It is a type parameter so you need to edit each type and associate parameter.
If I use multiple level nesting, I would use instance parameters in the nested family, associate with type parameters in the main family.  It is much easier to manage that way.
Message 6 of 11
Check your different nested door TYPES.
see this TYPE? No association.
Message 7 of 11
Just to be clear, you need to open and edit the nested family directly. Because of the way it is set up, that Type Parameter is not available to associate in the Parent Family.
Message 8 of 11
- Change Material Panel parameter in the nested families to Instance (there is one nest family, the parameter is named Door Finish, rename it to Material Panel for consistency)
- Associate Material Panel parameter with Door Finish parameter in  DP_DR_Panel family (this Door Finish parameter should be Instance as well)
- Associate Door Finish parameter in DP_DR_Panel family with Door Finish type parameter in the main family
Message 9 of 11
Message 10 of 11
aman.kumarRVKHA
Thank you, thank you very much.
Message 11 of 11
You're very welcome, @aman.kumarRVKHA.
Do me a favor and mark my first post (the one with the RFA attachment) as the Accepted Solution. I think that post will be more helpful to others that come across this thread.
Have a good day!
