Door Components
Door Components
Message 1 of 13
Door Components
I have downloaded multiple doors from different websites and all of them will not work. whenever I select component and chose a door it wont allow me to even click on a wall to place it.
Replies (12)
Message 2 of 13
Sahay_R
Don't select Component. Click on Architecture>>Door. It will recognize all door families that are loaded into the project.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 13
chrisplyler
If he is activating the Component tool, and then is able to select a "door" from the types drop-down list in the Properties palette, then that "door" isn't a Door family at all. Because of course you have to activate the Door tool to get Doors.
So the problem is a bit confusing the way it was stated.
If he is actually activating the Door tool, but is unable to select a host wall for placement of a door, I think the possibilities revolve around the inability to select walls in the first place.
Maybe the desired wall is in a workset that isn't editable.
Maybe the desired wall is in an option set that isn't active.
Maybe the desired wall is shown only as an underlay, but the Select Underlay Elements toggle is off.
Maybe the desired wall is not actually a System Family: Wall at all, but instead something that was constructed in another way?
Message 4 of 13
Sahay_R
Or maybe the desired door isn't a door at all, but a curtain wall door.
Rina Sahay
Message 5 of 13
I have also tried that and it did not work
Message 6 of 13
Sahay_R
Can you share one of the problem families?
Rina Sahay
Message 7 of 13
chrisplyler
You're going to have to explain further than "it did not work."
Maybe something like, "I clicked on the Architectural > Door tool. I selected a loaded Door type from the drop-down list in the Properties palette. I hovered over a wall in my active Floor Plan view but only get the little circle-with-line-through-it cursor." Or maybe, "When I try to place a Door I get a warning message that none of the elements I've created are visible." Or something helpful. Help us help you.
WHAT did you try and WHAT is the failure?
Message 8 of 13
Thank you for helping me I didn't know how to explain the problem I was having! you worded it perfectly  because the problem I was having was that I clicked on the Architectural > Door tool. I selected a loaded Door type from the drop-down list in the Properties palette. I hovered over a wall in my active Floor Plan view but only get the little circle-with-line-through-it cursor
Message 9 of 13
Was the wall created in your model or in a linked file?  Can you highlight the wall and share a screenshot of its properties?
Message 10 of 13
Capture.PNGI created the wall in my model
Message 11 of 13
Corsten.Au
Try to Place door in " Plan " View..not in 3D view..
you can place in 3D view but try axonometric or at some angle..
You can even place door, windows in elevation view, section view, ceiling plans...
Cheers!
Corsten
Building Designer
Message 12 of 13
ennujozlagam
yes go to the plan view and place it as suggested by @Corsten.Au. thanks
Message 13 of 13
Thank you so much for all your help! my problem was that I was trying to insert my components on 3D view
