Hello everyone
How can I add a model line (2D) in the family that follows the angle parameter of the door swing, so the line is drawn depending on the angle at which the swing is open?
Solved by ennujozlagam. Go to Solution.
https://www.youtube.com/watch?v=GnbedLNopP4
https://www.youtube.com/watch?v=pkeai4uxXRk
If it is only an arc and a line (Single lines) it is quite simple...add Symbolic lines in the door family (No need to nest anything)
