Door and Window schedule
atisklavins
atisklavins
Hello all,
I am using revit 2021, but I seem to have a problem with a door and wall schedule. As I try to attach image to schedule by using type image (field), revit does not gives me that option. But | can attach image to a image (field).
For wall it works as i should.
Could you advise me? Is there special field for doors and windows?
RDAOU
@atisklavins
For windows and Doors, the OOTB Type image can be set in Family Editor...
If you want an Type Image which is editable from the schedules in the project,
  1. ADD a Project Parameter Type/Image and assign it to doors and windows
  2. Use the new parameter as a filed in the schedule instead of the OOTB Type Image
  3. Go to Manage tab >> Manage Images >> Load the images into your project
  4. From the schedule, you can now assign the image you want
Set a Project Parameter for doors and windowsSet a Project Parameter for doors and windows
Add the Parameter as a field in the schedule instead of the OOTB Type ImageAdd the Parameter as a field in the schedule instead of the OOTB Type Image
Would adding the Type Image in the Door Family work for you?  You can do that and it will show up in the Schedule  and on the Sheet.
