How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Please help me I cannot make transparent the curtain wall sliding door. I already applied nested family and filters but still not transparent. Please see attached file. Thanks!
here
In 3d View you can see transparent but in elevation view it's not transparent.
what do you mean>? it is transparent , just click the door
if you want to see change the visual style to realistic
Like this?
Edit the sliding door family. Select the panel and edit this
Set this panel to shared
Once you load into the project, you will see the panel will set as transparent
That's exactly what I did above in the revised Project File I attached. 😉
Thank you @barthbradley and @syman2000.
How to buy
