Does copy monitor work for closed worksets from a linked Model
wpiotraschkeCHWR7
wpiotraschkeCHWR7
Greetings,
I'm wondering if a workset from a linked model is closed that happens to contain copy monitor elements, such as grids or levels, will copy monitor still be able to monitor these elements if their workset is closed.
I tried a brief search, but did not find anything matching.
Why don't you try it and see for yourself?
VGO=>Revit Links=>Worksets=>Custom
wpiotraschkeCHWR7
Hi Toan, thank you for taking the time to respond. Like yourself I too am busy and didn't want to spend a half hour to an hour trying to set up a test and was hoping the forum could provide a quicker (and perhaps reliable) answer. I was surprised by your response, because you are usually very helpful, but this response came off condescending.
Anyways, I did finally find time to try it for myself and the copy monitor does seem to still work. I should clarify my original post a bit as well. I closed the workset globally through the Manage Links and not simply hiding the workset in view templates or visibility graphics.
wpiotraschkeCHWR7
Barth, wasn't sure how to interpret your post. Nonetheless, see my response to Toan above.
I am willing to help people when they try and can't figure out the answers, not when they are too busy to even try.  I am busy or not is irrelevant.
