Do I need auto address to run revit
I need to download revit for my college work. I have been told I need to install auto and aswell for revit to work. Is this true or not.
RobDraw
Revit will work without any other additional downloads.
Rob
hmunsell
@Anonymous wrote:
...need to install auto and aswell for revit to work.
By "auto" I assume you are referring to AutoCAD?
Howard Munsell
mauricio_mssf
One program is independent of the other, you do not need to install both for Revit to work.
You can even have both if your workflow needs it. but it is not mandatory or necessary.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
