Division doesn't work in parameter
Message 1 of 20
Hi, I want to add formula to coverage parameter which calculates as foot print area/lot area. But I get inconsistent Units. I know that coverage is text parameter and foot print area/lot area are area parameters, but I can't find any solution. Thanks for helping
Replies (19)
Message 2 of 20
You cannot have a Text parameter as a result of math formula.  It should be a Number parameter.
Message 3 of 20
why is coverage a text parameter? Do you want it to return a value of "Too Much" or "Too Little" or "Just about Right"?
Message 4 of 20
I changed it to number and this time got another error "Division By Zero", and still doesn't let me write A/B
Message 5 of 20
Because your B = 0 base don your screenshot.  Change it to a different value before adding the formula.
Message 6 of 20
change it to a length parameter.
Message 7 of 20
Change it to Lenght, but it says" inconsistent unit"
Message 8 of 20
Add * 1" or / 1" to the end. I'd explain why this works, but I'm pretty sure you'll get it once you think about it.
Message 9 of 20
Looking at you screenshots I assume you want to get a ratio between 2 lengths, or between 2 areas. Is it correct?
Message 10 of 20
Absolutely,
Message 11 of 20
Basically you need to ensure three things:
1. Your equation does not divide by zero. EVER.
2. Your equation returns a value of the type expected (a number parameter in most cases).
3. If the parameter is expecting an area, that it returns SQUARED units (may have to multiply by 1 unit in order to square). If it is just a number that it returns NO units (may have to divide by 1 unit in order to remove units). If it is a length that it returns a united value (may need to multiply by 1 unit in order to add units to value or divide by unit to make squared units into units).
Message 12 of 20
Inside the family, the values are all 0, but inside the project, they are fillable as you can see in attached files. You are right the division doesn't work because the values are 0, but I don't know what to do.
Message 13 of 20
Just enter some value for A|1 to A|14 in the family so you can finish the formula. They are place holder numbers and can change in project.
Message 14 of 20
Ohh, Thanks it did work, but this time the rounding is grayed out 😞 I need to have 32%
Message 15 of 20
Edit the label format and change to Fixed  Percentage.
Message 16 of 20
How should I do that?
Message 17 of 20
Message 18 of 20
This is Awesome , thanks
Message 19 of 20
By the way, adding /1 and *1 as suggested by @Anonymous is a good way to iron out the Inconsistent units in a formula when the parameters in the formula are not of the same Type (Length vs Area vs Volume etc...).
Message 20 of 20
GHASEM_ARIYANI
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
