Dividing a line
4 REPLIES 4
552 Views, 4 Replies
Dividing a line
How to divide a line in equal segments?
Dividing a line
4 REPLIES 4
Use the split tool to make as many segments as you need. - don't worry about
the spacing. Dimension from end point to end point using the tab key for all
the segments. Hit Eq. for the dim string.
wrote in message news:5100752@discussion.autodesk.com...
Thanks for the hint about the tab key!!
How to hit the EQ.?
How to hit the EQ.?
I'd suggest doing the tutorials. Much of this is covered there and quite
basic to Revit.
wrote in message news:5100803@discussion.autodesk.com...
How to hit the EQ.?
basic to Revit.
How to hit the EQ.?
I found your instruction to be clear, although on my part it took me a few try’s to understand the tab key.
Thank you very much.
