Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any way to force a nested detail component to only Display When Cut in Section?
Thanks, eh.
Thanks, eh.
Toan is absolutely correct. If you nest that detail into another "cuttable" family and then load that host family into the project, it will show the detail only when when cut in view,
Edit: Toan - We must have been posting at the same time. It's a tie.
Hi again, I was just revisiting this family and noticed if you take an elevation view from the other side you do see the window head component in the view but the sill component is hidden. Curious - will post if I find and an answer to this one...probably a wayward mask somewhere.
The problem was in the lines - When I deleted all of them (converting didn't seem to help) the masking behaved as expected. I did have a mask in the head detail that worked on the one view only.
