Display settings for linked files patterns changing randomly
lucas_epa
lucas_epa
Since previous Revit versions there's a recurring problem happening: I set up the cut pattern for elements in the structure linked model in View Template for "solid fill" pattern (first picture). But when I close my model and open it again, sometimes the pattern is changed to "diagonal up" by itself (second picture). And this happens randomly. Does anyone know the solution for this?
Thanks!
curtisridenour
are you applying a view template at any point?
You need to check preserve overrides.
...oops. Scratch that. I see your talking about a RVT Link, not CAD.
Are you copying/pasting Links?  Let's see what's under your Revit Link tab.  Expand and take a Screenshot and post the Screenshot here.
