Display multiple Design Options on sheet
Is there a way to display multiple Design Options on a sheet?
When i change an Option in a Option Set, it changes in all Veiwports.
An Alternate work flow for having multiple plan configurations on a single sheet is also great.
Thanks in advance!
You should be able to create different views for different Design Options, go to VG > Design Options tab > and change it there for each view.
Set the Design Option for the View under VGO Design Options tab.  Not "Automatic".
Thank you!
Thank you!
