I think this is an issue from version 2023 and has not been fixed yet. When using the HI or HR command in Revit family, objects disappear inexplicably. Is there a mistake in my operation or is it simply a display error? I would appreciate an explanation
Hi @duypham.isystem,
Is this in the Family editor and are the solids joined?
Depending on selection (nested original solid or joined total) it can be visible during selection but can update after to reflect the hidden total solid.
See if it still behaves like this if you unjoin all solids, if not it's a cause of the parent visibility updating to it's child elements (the joined original solids)
Maybe post the family?
- Michel.
The blocks are properly connected. However, if there is an issue with that, I believe it is a software error. I will send you the file shortly. Thank you for your support.
