Displacement tool not available in 3D Isometric view for 2016 and 2017 versions
jagostinho74
Message 1 of 10
jagostinho74
Would like to report something I feel that is a bug.
Revit Help mentions that displacement views are available in 3D and perspective views, however, it is not available in Revit 2016 and 2017 versions. It is available in 2015.
See screenshots from different versions attached to this post.
Anyone else also noticing this?
Kind regards,
Joaquim
Assistant BIM/CAD Manager
Manchester, UK
Replies (9)
Message 2 of 10
L.Maas
No.
Revit 2017.2
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 10
semko_dm
Hi!
In my case, everything works fine in 3d and in perspective.
Revit 2017.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 4 of 10
jagostinho74
Interesting.
Just installed 2017.2 update and I still cannot have it.
Manchester, UK
Message 5 of 10
chrisplyler
It's working for me in 2017.1
Message 6 of 10
jagostinho74
I tried it in more than one machine here.
Have a feeling that might be one of the Add-Ins....
Thank you very much you all for reporting back from your end.
Will report back in case I find out what is causing it.
Manchester, UK
Message 7 of 10
semko_dm
I think that it's because of one of the add-ins.
Dmitriy Semko
BIM-Manager
Blog
Message 8 of 10
Alfredo_Medina
After you select the element, have you clicked on View > Displace element? I don't see the View tab being the current tab in your screen captures.
Message 9 of 10
jagostinho74
Found it!
The "Show annotation categories in this view" box in the VGO window must be checked. Even though none of the other boxes need to be. Just this main one. Even the "Displacement Path" box may be unchecked. If you do not want o show it in the view, obviously.
No Add-Ins to blame, this time. And nothing to do with the Revit versions indeed.
Thank you all for your replies.
J
Manchester, UK
Message 10 of 10
chrisplyler
Wow, I never would have thought of that. Good job figuring it out!
