Disable zoom when undoing
PieterL_TM
PieterL_TM
Is there anyway to disable the automatic zoom when pressing Ctrl+Z (undo)?
This is so incredibly annoying!
Alfredo_Medina
Normally, Revit does not zoom when you do Ctrl+Z. Have you checked View > User Interface > Keybord Shortcuts?  Search for Zoom. Do you see Ctrl + Z there as a shortcut for Zoom in or out?
hmunsell
@Alfredo_Medina  a lot of times if the Undo included a view position change, like a Zoom in/out, it does the zoom as part of the "undo".
@PieterL_TM unfortunately I don't know of any way to prevent that. it is just following the commands that were entered while undoing.
Howard Munsell
Alfredo_Medina
I see. However, I understand that if the user goes to the Undo history, and goes back a bunch of commands. But the user is saying that the issue happens by using Ctrl+Z to undo.
hmunsell
if i have a bunch of undo's, I usually prefer using the Undo History too 👍.  I make a point to show it as an option in all the classes I teach.
Howard Munsell
