Dimensions do not display center graphics when dimensioning families in a linked model
gsucci
gsucci
as per subject, when I dimension elements from a linked model (light fixtures from a electrical sub model) the dimensions do not show the "CL" graphic and line-type, even tough the references (center) are correct in the family.
I can insert an instance of the same family and it will show properly.
This is Revit 2019...
Thank you
Copy the Link Light Fixtures to the Parent via Copy/Monitor on the Collaborate Tab.
gsucci
This is not feasible for more than a few elements.
thank you
RobDraw
Why not?
Rob
