first of all, get to know the [tab] button on your keyboard. When hovering
over a point and hitting the TAB you will cycle through all possible
attaching-points (if you wait a second you can read to which object the
point is actually related on screen).
You will see that if you'd have an orthogonal situation you could pick
POINTS too instead of faces or ends, doing this you could dimension a
diagonal for instance [so here's your non-orthogonal dimension]
good luck and happy Revitting!
"JTB" schreef in bericht news:413aadaa_3@newsprd01...
> Very new to Revit I try to work with dimensions. I see that only
horizontal
> and vertical dimensions are allowed. Also, dimensions must have an object
to
> "touch" at both ends. When I try to use a detail line for example as a
> reference object and then delete it, the dimension goes with it. I guess
> there is a way to place dimensions everywhere but I don't know where to
find
> it. Also I know that a wall can be dimensiond even if it is not vertical
to
> another but I don't understand what I am doing wrong
> Please help me a little.
> TIA
> Dimitris
