dimensioning inclined wall
Hi there
I am using Revit Architecture 2016, I am trying to dimension an inclined wall , it happens to dimension the intersected parts of the wall. but I am not able to dimension the whole length of the inclined wall as the picture I have attached.
RDAOU
Use TAB key over the intersection/end point of the wall >> select the point node and measure aligned node to node
Thankyou very much RDAOU
This worked really well just recognizing that node is difficult. Any way we can make them display bigger?
RDAOU
You are welcome;
no there isn't just use the mouse wheel to zoom out a little. the more you zoom out the bigger you see it
