Dimension String "Replace with Text" multi-line text
erik_luthringshausen
When using the "replace with text" functionality of a dimension string, the text comes out in a single line. Is there a way to adjust the text or text box so that it is multi-line?
vitorbortoncello
Replace With Text for dimension is strictly single-line
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
mari.shimode
Hi @erik_luthringshausen, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
Mike.FORM
You can use a combination of the "above", "replace with text", and "below" fields to make it look like multiline.
