Different visibility for same view
dgoff96
dgoff96
What is the best way to show one view with several different visibility settings (ie, full elevation, sheating removed, structure only) I've currently duplicated the view and then hidden the marker for the dupliates but seems clunky.
constantin.stroescu
I use , for this purpose, View Templates.
Constantin Stroescu
dgoff96
Hi Constantin,
I have view templates for each version i want, but do I still have to duplicate the views? Is there a way to apply a multiple view templates to a view and choose depending on what you want?
constantin.stroescu
I'm not sure I understood you well, but if you want to make a study with several different settings including materials , maybe Design Options can be a solution....
Constantin Stroescu
chrisplyler
If you only need one view and you want to change it as you see fit, then just re-apply whatever view template is appropriate at the time.
If you need several versions of the view on sheets permanently, then duplicate the view however many times you need, and apply the appropriate view template to each one, and change their disciplines if appropriate.
I don't know what you mean by, "...hidden the marker for the duplicate." Duplicating a view does not create any kind of "marker."
David_W_Koch
Duplicating an elevation creates another elevation callout for the duplicated elevation.  I believe this is what the OP means by "marker".
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
dgoff96
Yes David, I was referring to the duplicated callout when I said marker. I just assigned the ones I wanted to hide a different callout type and applied a filter to the view to hide them. Thanks for the help!
