Hi.
I'm using gray tone for existing walls for my project and I found out the tones are different in some places.
They are under the same phase filter. Does anyone know why this is happening?
Thanks!
Solved by barthbradley. Go to Solution.
Hi Kaylin, This could be for a few reasons but I will try to list out possible troubleshooting options.
Try these and see if they give any clues, hope that helps.
Hi! Thank you so much for your reply but unfortunately I was not able to solve it.
I'm attaching my revit file and can anyone look into the model and help me figure out the problem?
The problem usually happens in the first floor..
Thank you!
@Anonymous
No file attached...make sure to drag and drop it into the right section of the reply
