Diagrammatic plans,
Diagrammatic plans,
nathan.garcia7M3RT
Diagrammatic plans,
nathan.garcia7M3RT
is there an option or way to turn shadow receiving off on certain materials? or to assign certain objects/objects with a certain material to not cast shadows?
I'm working on a site plan where we want to see exterior walls casting shadows, but no shadows on the interior plan. Any alternative way of tackling this without post processing would also be appreciated. I know this can be done in several other programs easily but I'm are trying to automate the process.
thanks
constantin.stroescu
 for one View only:
  • select the elements that you do not want to cast shadows and Modify >View >Override by Element >Surface Transparency - increase a little the level of it...
for all Views
  • allocate to all the selected objects a slight transparent material
Constantin Stroescu
What about overlaying views on sheet?
constantin.stroescu
if you think that the slight transparency still bother you , then you can overlap the partial transparent with shadows over the duplicate with no shadows in a sheet view:
  • image 1 -the view without transparencies and without shadows:
  • and image 2-  the Duplicate with shadows and selected items override with a slight transparency:
the transparency doesn't bother me, but if you are not pleased , then overlap image 2 over image 1
  • the image placed on sheet : image 2 over image 1:
Constantin Stroescu
lim.wendy
Hi @nathan.garcia7M3RT ,
Welcome to the Revit Architecture forum. Thank you for submitting your question in our discussion forums.
It looks like Constantin's suggestions to hide shadow from certain objects with a certain material help,  so for now, I will mark this thread as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
nathan.garcia7M3RT
thanks so much this solution worked perfectly
You're welcome.
