How could I create in Revit a similar curtain wall geometry as shown in the attached picture?
Thank you for your time!
Solved by Yien_Chao. Go to Solution.
Mass the shape and apply Curtain Wall System by Mass Face. Or, Divide the Mass Surface and apply a Pattern-Based Curtain Panel to the Divided Surface.
I believe you panels are flat? so just attach the top of your curtainwall to a reference plane?
If the question is to get curved curtain wall, then use a simple wall for the geometry and the place the mullions as a face based family.
If you are using system panel, you can attached the curtainwall to the underside of temporary floor or roof.
I have to cut the top of the Curtain wall diagonally and I did it by using a roof geomatry above and attach it to the roof, so, I could resemble the cut view.
Wanted to see if there is a professional way to do it, not as rudimentary. 😄
Thanks!
